How to Rip Blu-ray to Audio with DVDFab Blu-ray Ripper?
06/14/2023
DVDFab Blu-ray Ripper not only rips Blu-ray to various videos, but also rips Blu-ray to audios in different formats. If you want to find an outstanding Blu-ray to audio ripper, Blu-ray Ripper is here for you to try out for free. Next is a step by step tutorial about how to do this.
Step 1: Start up DVDFab Blu-ray Ripper, load in the Blu-ray source
Start up DVDFab 9, choose Ripper option. Then insert Blu-ray disc, or drag and drop Blu-ray folder/ISO saved on your PC into the program, so that DVDFab will analyze and open it. After the movie is in, the longest movie title will be selected by default. You can freely choose any titles for conversion. And the audio tracks can be changed easily.
Step 2: Choose an audio profile
Click to open Profile box, go to Format, then navigate to audio on the left panel. Just choose the audio profile you like among the multiple ones.
Step 3: Set audio parameters
Click Advanced Settings button on the main interface to set audio parameters like bit rate, audio channels, volume, split by chapter or not, and so on.
Step 4: Start conversion
Now go back to the main interface to hit Start button to start conversion. During the process, you can view detailed progress info.
OK. Now leave the rest to DVDFab. Very soon everything will be done. For more info about DVDFab Blu-ray Ripper, just go to: http://www.dvdfab.cn/blu-ray-ripper.htm
